Clutch slip mugello 225
mr mugello
Clutch is slipping . Standard clutch fitted apart from stronger springs . New springs fitted with new plates last time. Clutch was nice and light in use. Just wondered what is the life of the springs. Should I be replacing them with new ones every time I refit new plates ? Cheers
bazza3004
What type/grade of oil are you using in your engine
mr mugello
Clutch has had reasonable working use over a few years with standard 90 oil
bazza3004
If your going to change plates id try something like motul 10/30 2t transoil swapping to this cured the slipiwas getting on my imola
