Jet 200 leg shield hardware
RBG
I've a 2nd question for you ever so knowledgeable gentlemen
I'm going to be refitting my Jet leg shields and rear runners in the not so distant future.
When I removed them I had an assortment of fasteners holding them down every one had a
finishing washer with a either a pan head, Slotted countersunk flat head, slotted countersunk oval head
or a Philips oval countersunk.
I've been looking for a list of what goes where and what was originally used.
I think I need 12 finishing washers 12 x countersunk and 8 x slotted pan head
Are the Countersunk screws Slotted or Philips head, flat or oval ?
when I removed them, the Philips looks a little more corroded so could be older or just
of a shitty quality.
Does one of the shops sell a kit or do any of you guys know what's needed and where it goes?
Many Thanks
HxPaul
If yours is the model with legshield runners and not mats,you can buy a complete runner fastener kit with all the correct bolts,nuts and washers.
RBG
It's got the Mats
It may yet get some holes drilled a set of scootopia runners, rubbers and a hardware kit if I have no luck.
buzzsolomoto
Main scooter: Jet 200 p200e
phillips are original on Spanish scoots
RBG
buzzsolomoto wrote:phillips are original on Spanish scoots
Many Thanks for the info.
