Sip rims and rear hub studs
Posted: Wed Nov 23, 2016 4:44 pm
by shocky
Not happy with the lack of thread what's my options
Sent from my SM-G903F using Tapatalk
Re: Sip rims and rear hub studs
Posted: Wed Nov 23, 2016 5:40 pm
by garry inglis
Are they the longer studs you get with the wheeels if not they need fitting
Posted: Wed Nov 23, 2016 6:00 pm
by ducksta
where do you get the longer studs from
Posted: Wed Nov 23, 2016 6:22 pm
by drunkmunkey6969
garry inglis wrote:Are they the longer studs you get with the wheeels if not they need fitting
You are thinking of the Lambretta version...
Posted: Wed Nov 23, 2016 9:37 pm
by cartmel808
You can buy longer studs to fit the Vespa hubs from Beedspeed & they're spot-on with the SIP tubeless rims...
Posted: Wed Nov 23, 2016 10:20 pm
by shocky
The 32mm ones ?
Posted: Wed Nov 23, 2016 11:21 pm
by cartmel808
shocky wrote:The 32mm ones ?
Yes they're the ones - M8 x 32mm...
by Muttley McLadd
Similar problems with the Pinasco ones.
I got a bag of these:
They stick out this much when fitted:
Posted: Wed Nov 30, 2016 8:38 pm
by shocky
Sorted with some 10.9 m8x40mm dome cap screws I may trim the 40 to 35mm
The original studs were a ball ache to get out I drilled the back out and welded a nut on 3 came out one had to be drilled right through and eventually came out with a stud extractor one sheard of flush and I had to drill it out and retap
