Sip rims and rear hub studs
Not happy with the lack of thread what's my options
Sent from my SM-G903F using Tapatalk
garry inglis
Are they the longer studs you get with the wheeels if not they need fitting
ducksta
where do you get the longer studs from
garry inglis wrote:Are they the longer studs you get with the wheeels if not they need fitting
You are thinking of the Lambretta version...
cartmel808
You can buy longer studs to fit the Vespa hubs from Beedspeed & they're spot-on with the SIP tubeless rims...
The 32mm ones ?
cartmel808
shocky wrote:The 32mm ones ?
Yes they're the ones - M8 x 32mm...
Similar problems with the Pinasco ones.
I got a bag of these:
They stick out this much when fitted:
Sorted with some 10.9 m8x40mm dome cap screws I may trim the 40 to 35mm
The original studs were a ball ache to get out I drilled the back out and welded a nut on 3 came out one had to be drilled right through and eventually came out with a stud extractor one sheard of flush and I had to drill it out and retap
