Malossi or Pinasco P200 engine casings?
andyvep
Main scooter: Vespa PX200
Anyone got experience of these? Which is better quality? Better for modifying? Any recommendations?
225worb
Main scooter: Vespa 225, Falc , 230 S2
Ive built up a new motor using Pinasco reed cases, the malossi ones dont touch the pinasco in regards to strength!!!
It does depend of course how much power your planning on putting through them!!
After serious engine casing failures over the years (with the same set up around 28bhp) and spending alot of money every time getting replacement cases machined and welded the Pinasco will/should/fingers crossed cure the problem !!!!Hmmmmmm!
The Pinasco ones are beefed up in all the achiles heeled places , massive base gasket area , better alloy casting . T5 Flywheel bearing...blah blah..
Good luck..
    Users browsing this forum: No registered users and 60 guests
