Dyno
ricardo59
Main scooter: vespa px 125-180
Hi all
just had a new Polini 177 kit fitted and was advised to run in for 500km only using 3/4 throttle and to get it Dynoed, my question is do i do the 500km before i have it dynoed?
gaz_powell
You should have it ran in before the dyno work or have the bore/piston clearance adjusted accordingly if short of running in time.
Check with the kit instruction but 500km doesn't seem much.
garry inglis
If you have the jetting set right ok to run in but if it's running lean you could seaze it up I would get it dynoed to check and they will set it a tad rich for running in
ricardo59
My mechanic has set up the carb for me, he has jetted it to run rich untill it is run in
gaz_powell
As Mr punch says that's the way to do it.....
