chrome frame ring removal
mr mugello
Hi .
I really need to replace the original rusty chrome ring . I cannot seem to budge the ring after taking out the race. I was looking at using the heat method. Is it possible to over heat and disstort the frame when doing this? Will a heat gun have enough power to do this job or would I need a blowtorch ? Will I need to heat frame when refitting parts ? Thanks
garry inglis
Hi used along cold chisel comin from bottom and tap out a bit of heat from the gun will help clean out when re fitting new one use rubber hammer good look
Scooterdude
I had to thrash mine out from the bottom with a long steel bar and a very big hammer. But be carefull what you replace it with! I started by trying to fit a scootopia one that apart from being the wrong shape cut a groove in the back of the headlight. I then spent forty something quid on a Casa one in the belief that as it was Casa and expensive it would fit, well it ain't great I can tell you and about six months down the road I've noticed the Chrome plating is beginning to flake off! With hindsight I would have been better off replating the original one.
mr mugello
Crikey. Thanks for pointers. Making me think to just leave it alone. Patina comes to mind. Nothing is straight foward it with the remade items. Anyone have more experience with the heat method removing.
The way I have done it in the past is to place a block of wood beneath the ring and tap it all around a bit at a time. eventually it budged.
YAMLAM
i had to replace one for a mate recently. i bought a 1mtre length of 16mm studding, ran a nut down about 35mm then put a rear hub cone on with the larger taper facing up, after heating the fork tube a bit i inserted the studding from the bottom end of the tube and used a club hammer to bash the old ring out, i had to re heat the tube four times before the bugger came out.
win or lose have a booze
mr mugello
Are there anyremade rings as good fit and quality as original about, if damaged removing. Was looking at scootopia ones.
hendy
I used an eBay stainless one. Perfect.
I've got a Scootopia one on mine. No problems with it as far as I'm aware. Fit well enough. But time will tell.
Scooterdude
I'm sure I heard somewhere that the eBay stainless ones are made wrong thus not making it possible to use the steering lock.
