Higher than normal tick over
Posted: Fri Oct 07, 2016 7:35 pm
by alanscottj
Evening!
Just been for a spin on the scoot and noticed that it is idling much higher than usual - about 3000 rpm - constant, not increasing. Adjusting the idle screw is having not impact whatsoever - could it be an air leak or something else?
Scott
TS1 - TMX - Franspeed Super - Varitronic
Re: Higher than normal tick over
Posted: Fri Oct 07, 2016 7:50 pm
by Knowledge
It could be an air leak.
Posted: Fri Oct 07, 2016 7:53 pm
by alanscottj
Yeah, that's what I'm thinking - I have a leak down tester so will have a test over the weekend to rule it out. As I will have to take the pipe off it'll be a good chance to swap the front sprocket
Posted: Fri Oct 07, 2016 8:16 pm
by alanscottj
Found it! Just had a closer look at the carb to check the slide wasn't sticking and tried to twist it to check it was still on tight and the rubber split! It's only been on a couple of months
Ok- next question - Who does the best carb rubber for the TMX35 ???
Thanks
Posted: Fri Oct 07, 2016 9:50 pm
by Toddy
alanscottj wrote:Found it! Just had a closer look at the carb to check the slide wasn't sticking and tried to twist it to check it was still on tight and the rubber split! It's only been on a couple of months
Thanks
What type you got on now ? I use the MB ones on my tmx for the last year been fine
Posted: Fri Oct 07, 2016 10:07 pm
by alanscottj
What type you got on now ? I use the MB ones on my tmx for the last year been fine[/quote]
Will check tomorrow - Chiselspeed put it on a couple of months ago when I had her dyno'd there.
Posted: Fri Oct 07, 2016 10:25 pm
by Toddy
alanscottj wrote:What type you got on now ? I use the MB ones on my tmx for the last year been fine
Will check tomorrow - Chiselspeed put it on a couple of months ago when I had her dyno'd there.[/quote]
Are you sure nothing's pushing the carb putting stress on the rubber or the jubilee clip has cut it ?
Posted: Fri Oct 07, 2016 11:39 pm
by alanscottj
Toddy wrote:alanscottj wrote:What type you got on now ? I use the MB ones on my tmx for the last year been fine
Are you sure nothing's pushing the carb putting stress on the rubber or the jubilee clip has cut it ?[/quote]
I have a feeling the jubilee clip cut it - it was on very tight.
