what crank to use for Quattrini m1xl
Mark G
Main scooter: Ts1 px177 gts300
Hi im building a Quattrini m1xl and and would like to know what the best crank to use. it looks from what I've seen you can only use a full circle which is fine, im going for a 60mm stroke but can only find a MAZZUCCHELL can i use a bell crank? I like the look of the scooter services bell crank has anyone used one any feed back or advise would be much appreciated
ducksta
Standard ok as your not using the rotary induction
cartmel808
I'd say stick with a full circle crank as that will work best with the direct induction M1xl barrel... the bell crank is designed for a case induction reed set-up
