Who does the best LED rear brake light?
Many thanks.
Scott
Best LED rear brake light?
alanscottj
- Main scooter: Lambretta GP SS250 Casa
- garry inglis
- Main scooter: ts1 230 and rb200
holty on here he makes and sells them ive one on both my scoots fit and work perfect £20
Scooterdude
- Main scooter: Lambretta LI 125 S3
Don't be tempted to just get a led replacement bulb, they are very dim I ended up putting my normal bulb back in!
alanscottj
Cheers troops!
rainbowrunner
- Main scooter: Series 2, RT 195
just fitted a BGM led unit, bright as hell, well chuffed.
Had a couple of the BGM ones and they are pretty good .....for the 6 months they work....
alanscottj
Ordered one from Holty
- HxPaul
- Main scooter: lambretta Li 150
Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
Scooterdude
Is yours the full DC system with battery? Mine is AC no battery and I'm using a 55watt halagen front bulb which is very bright, but as you say when you brake even with the led back bulb the front light almost dies.HxPaul wrote:Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
I read somewhere those led back light units must be used only with DC current ?
