Best LED rear brake light?
alanscottj
Who does the best LED rear brake light?
Many thanks.
Scott
garry inglis
holty on here he makes and sells them ive one on both my scoots fit and work perfect £20
holty
Main scooter: lambretta gp
ha, i just put a reply on your other post.
Scooterdude
Don't be tempted to just get a led replacement bulb, they are very dim I ended up putting my normal bulb back in!
alanscottj
Cheers troops!
rainbowrunner
Main scooter: Series 2, RT 195
just fitted a BGM led unit, bright as hell, well chuffed.
immylam
Had a couple of the BGM ones and they are pretty good .....for the 6 months they work....
alanscottj
Ordered one from Holty :D
HxPaul
Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
Scooterdude
HxPaul wrote:Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
Is yours the full DC system with battery? Mine is AC no battery and I'm using a 55watt halagen front bulb which is very bright, but as you say when you brake even with the led back bulb the front light almost dies.
I read somewhere those led back light units must be used only with DC current ?
