sip speedo fuel gauge
smoore-gt225
Main scooter: lambretta GT200
Hi Probaly a daft question but I think ive set up the speedo correctly does the fuel gauge show all white sections if full and each white section go out as it empties if you know what I mean
cheers steve
Tractorman
Main scooter: Lambretta li150 special
No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
smoore-gt225
Tractorman wrote:No, you should ride with the tap set on reserve and when the fuel level reaches the reserve the mileage readout will flash alternate with 'FUEL'. So there is no actual indicator of what's in the tank.
thanks for reply but what was the point in incorporating a fuel gauge into the speedo than it says fuel gauge in instructions
I know the lammy ones flash
cheers steve
Tractorman
cheers steve
Sorry, I did not realize Vespa ones are a bit more high-tect.
smoore-gt225
cheers steve
I think theres a lot more room to fit everything in. ive emptied the tank now to fit a fast flow tap so I will check it as I refill and see what happens too the gauges
Padge
Main scooter: 1969 Lambretta gp
all the bars light up white, when you get down to the last bar the fuel light should come on, then the last bar will flash
