TS1 JETTING ADVICE NEEDED
stafford
TS1 225 using a 30mil amal carb with a pm tuning exhaust can some one give me some advice on jetting or a starting point for the jetting please,its a new kit on the bike thanks in advance ROOB
J1MS
A starting point... no two engines are identicle but this usually gets them running...
330 main jet ... May need to be bigger or smaller but it should run on this well enough to fine tune.
108 or maybe 107 needle jet if it bogs down too much around mid throttle.
4 slide or possibly 3 1/2... If it is a little weak.
30 pilot.
air screw about 1 turn out..... but at least a 1/2 turn out...
you only have a choice of one needle as standard ... 2D1 put it on the 2nd or 3rd clip from top.
This should get it running, but be careful that its not too weak.. It will still need fine tuning..
If you contact PM Tuning they should give you there settings for use with this carb.. they really are quite helpfull
Choke jet... just make sure its got one..!!
