oil leak at kickstart
roadrunnerian
hi,i have an oil leak on my kick start shaft I have changed the oil seal 3 times,fitted new bushs and loctited the seal in anyone had the same problems, can only think now of changing the side case and kick start shaft. :D
Scooterdude
Are you sure you Dident let the lip of the seal reverse when you fitted it? I found it a tricky blighter to get right when I rebuilt my engine, put some grease around it and check it by sliding a small screwdriver around the joint to check.
bazza3004
Hi scooterdude i renewed the inner bushes and seal on roadrunnerians case. The seal lip is as it should be and ian told me it only leaks (very slightly) after a decent run. Despite having to tap the seal in to casing were wondering if once hot its seeping from case and outer seal face.
Scooterdude
Many of the seals currently available from scooter shops are single lip if your using one of these try a double lip one, may make all the difference you can get em from specialist seal suppliers on line.....get yer magnifier out though to cross reference the numbers, they're tiny!
Failing that try Harry Barlow, pro porting he does em.
    Users browsing this forum: Google [Bot] and 11 guests
