Page 1 of 2
Stripped thread cylinder stud
Posted: Mon Aug 29, 2016 5:30 pm
by vicvega
Looking for the best repair for the engine casing, has anybody tried these before
www.memfast.co.uk/shop/Vprod2.asp?cat=2250004326
Sorry couldn't paste picture, they're self tapping inserts, thinking might be stronger than helicoils?
Re: Stripped thread cylinder stud
Posted: Mon Aug 29, 2016 5:35 pm
by sean brady scooters
not seen those before myself but they do look similar to the time sert thread repairs ,which are very good :)
Posted: Mon Aug 29, 2016 5:43 pm
by vicvega
Cheers Sean, I'll give them a try.
Posted: Mon Aug 29, 2016 6:38 pm
by gaz_powell
Never seen them before but they look good and at right price to have in, just in case.
I'm gonna get some M6 and M8
Posted: Mon Aug 29, 2016 7:05 pm
by holty
if its one of the barrel studs thats stripped, i would consider getting it welded up, then having it re-tapped, you will probably find that an insert will not be strong enough, also its hard to get a seal around the stud once repaired, i presume its a lambretta where there isnt much material around the stud hole to start off with, and not much gasket face either, a welded repair would be the best option.
holty :D
Posted: Mon Aug 29, 2016 8:04 pm
by Chris in Margate
Still a little bit of meat below to drill and tap. Fit PX stud with loctite.
Posted: Mon Aug 29, 2016 8:34 pm
by a.lo.v2
looks like the hole needs to be bored to 11mm first, is there enough room?
Posted: Tue Aug 30, 2016 3:36 pm
by shocky
Beedspeed and others do an oversize thread stud at one end I'd try one of those before I started drilling big holes
Posted: Tue Aug 30, 2016 3:41 pm
by shocky
Posted: Tue Aug 30, 2016 4:35 pm
by vicvega
Cheers, hedging my bets & have ordered both.
