Koyo bearings?
DaveTomo
Main scooter: SX 200
Slowly over the course of this year getting a few bits together ready for the winter overhaul - full engine strip down. Anyway, always used FAG/SKF bearings , came across these on the interwebs
http://www.gofullthrottle.co.uk/Lambret ... gs/275.htm#
Just after some feedback really, not so much the shop (although that would be good) but the bearings, primarily the Koyo ones ( INA I'm happy enough with) as have never used them. Will be going in a GT200 big block kit, any feed back appreciated about the quality/longevity of the bearings.
Koyo are good bearings, Jap manufactured. I recommend them.
DaveTomo
Cheers Dan
Sent from my SM-G900F using Tapatalk
bazza3004
Koyo are decent bearings used them in a few rebuilds with no problems. Use to use them in my skateboards wheels too :D
DigDug
drunkmunkey6969 wrote:Koyo are good bearings, Jap manufactured. I recommend them.
You fit them... 8-)
Did you have to do that?
Used to.
The shop has good feedback for supplying gts parts especially service kits , im not sure the rear hub bearing is included in that kit altho it says it is
DaveTomo
Thank you chaps , appreciate the feedback
eden
I don't use them anymore.
Muppet
skf or fag; never had a problem
C’est la vie
