Remove bearing from magneto housing
kejj
Hi all
Is it possible to remove the NU2205 bearing from the mag housing without damaging it?
If yes then how to go about removing it?
________________________
http://tv175.wordpress.com/
DigDug
Did you have to do that?
dennis
Main scooter: 1 gp 1 special
used to be a guy on youtube showed you how to do it,he gets the mag housing hot and i mean hot and gives it a tap and it pops out
YAMLAM
yep, heat the mag housing up till it will boil spit, using gloves pick it up and give it a good thumping on a flat surface( I actually use two bits of 4" sq fence post bolted together ) bearing should drop out.
win or lose have a booze
garry inglis
I heat up mag and use an old engine mount the bigger ones not li and they fit perfect as a drift tool and just tap it out it fits the outer lip so no damage
EddieStone
Take the mag housing off, strip it (clips, seals etc), then stand it on a cooker ring to heat it up. The hotter you get it, the easier it will be. Get it really hot, use oven gloves to move it onto a scrap piece of wood and tap it out using a good sized socket. Obviously get the right sized socket ready first. You don't need to whack it, just tap it out. If it gets stuck, heat it up and start again.
Takes longer to describe than to do.
HxPaul
Remove the circlip,pry out the inner oil seal and heat the mag housing on a cooker/hob until it is about 100 degrees c.Next knock out the smaller oil seal,this will in turn knock out the L-shaped washer and the bearing.
Muppet
heat hit n hope :-)
C’est la vie
Scooterdude
Muppet wrote:heat hit n hope :-)
Yeah, hope your missus doesent catch you using her cooker!
kejj
Great, thanks for the Ideas! Cant do it at home since we have a gas cooker! I will heat it with a heat gun and try to hit the outer seal out with a engine mount.
