TS1 Jetting
TS1-200
Been running my TS1 in various guises for 15 years or so current setup is 60 mm crank, 116mm rod,Racetour piston, 34 mm Delly, NK pipe, performance is good, query, I have been plagued by a mid range light throttle opening (45- 55 mph) spluttering which I have put up with, but chatting to someone recently he suggested I try a weaker atomiser, currently DQ268, K38 needle top clip, 170 MJ. On his suggestion I have fitted a DQ266 atomiser and I must admit it is better, obviously weaker but how much a change is this mixture wise, done some low speed plug chops and seems fine, any advice, will have to get out on the by pass to do some proper plug chops.
Keep on keepin on
