3 leg glaze buster
Tosh
which oil or substance is best to use on a cast iron barrel
kevspeed
I used brake fluid,I had a shed load given to me,so not expensive!,I would have thought any thin lube would be OK.
Tractorman
I would use paraffin or diesel oil rather than an oil.
Tosh
Thanks to you both for the info
Tosh
Oh! before I forget whats the best for cleaning the barrel out after Ta
Tractorman
Paraffin to take the heavy off and then brake cleaner followed by an air blast.
