Fuel pump
Posted: Fri Aug 12, 2016 9:06 am
by smiffy1968
I am about to fit a vacuum fuel pump for my 220 Malossi, running a heavily modified Si 24/24G carb. Anyone done this before?
Re: Fuel pump
Posted: Fri Aug 12, 2016 8:36 pm
by wack 63
Not on a standard carb,but you will need a bypass or the pressure will overcome the float needle and lead to flooding.
Re: Fuel pump
Posted: Mon Aug 15, 2016 12:02 pm
by Ginch
Re: Fuel pump
Posted: Sat Sep 10, 2016 2:47 pm
by smiffy1968
Thanks gents. I have a Mikuni pump with a 5mm bore pulse inlet. The hosetail i got from SiP is a Polini item with only a 3.7mm bore. I am thinking match the hosetail bore to the pump inlet size? Any experience or views greatly appreciated.
Re: Fuel pump
Posted: Sat Sep 10, 2016 2:48 pm
by smiffy1968
Keihin flat slide carb now going on engine.
Re: Fuel pum
Posted: Sat Sep 10, 2016 7:53 pm
by rosscla
I'm heading the same way with mine, have spent hours trying to get it to run anything like right with an SI
Re: Fuel pump
Posted: Sun Sep 11, 2016 3:44 pm
by smiffy1968
Had similar fun rosscla.
