largest rear Tyre
Posted: Wed Aug 10, 2016 10:14 pm
by YAMLAM
whats the largest rear tyre you can fit to a Lambretta without removing the bump stop
got a 110/80 x 10 on at present.
Re: largest rear Tyre
Posted: Tue Aug 16, 2016 6:34 am
by Ilango
YAMLAM wrote:whats the largest rear tyre you can fit to a Lambretta without removing the bump stop
Is the tyre not rubbing against the inner side of crank case? Have you introduced more shims behind the rear brake drum cone?
Posted: Tue Aug 16, 2016 10:20 am
by 10 inch Terror
110/90 X 10 I believe is the largest.
Posted: Tue Aug 16, 2016 11:21 am
by YAMLAM
Is the tyre not rubbing against the inner side of crank case? Have you introduced more shims behind the rear brake drum cone?[/quote]
tyres definatly not rubbing on the casing, as to wether its spaced out, i dont know, it`s on a Chopper i bought and now need to replace the rear as it`s getting very close to being a slick !
Posted: Tue Aug 16, 2016 12:32 pm
by 10 inch Terror
A 110/90 X 10 will fit without touching the bumpstop, you'll need to fit a spacer under the cone though. MB sell them, and they work well.
Posted: Wed Aug 17, 2016 10:37 pm
by YAMLAM
10 inch Terror wrote:A 110/90 X 10 will fit without touching the bumpstop, you'll need to fit a spacer under the cone though. MB sell them, and they work well.
thanks for that info.
Posted: Sat Aug 27, 2016 3:03 pm
by shocky
It depends how far your rear hub cone fits into the hub son only go halfway in :roll:
