largest rear Tyre
YAMLAM
whats the largest rear tyre you can fit to a Lambretta without removing the bump stop
got a 110/80 x 10 on at present.
win or lose have a booze
Ilango
Main scooter: SIL Vijai Super
YAMLAM wrote:whats the largest rear tyre you can fit to a Lambretta without removing the bump stop
Is the tyre not rubbing against the inner side of crank case? Have you introduced more shims behind the rear brake drum cone?
10 inch Terror
Xbox live gamer tag: No.
110/90 X 10 I believe is the largest.
YAMLAM
Is the tyre not rubbing against the inner side of crank case? Have you introduced more shims behind the rear brake drum cone?[/quote]
tyres definatly not rubbing on the casing, as to wether its spaced out, i dont know, it`s on a Chopper i bought and now need to replace the rear as it`s getting very close to being a slick !
10 inch Terror
A 110/90 X 10 will fit without touching the bumpstop, you'll need to fit a spacer under the cone though. MB sell them, and they work well.
YAMLAM
10 inch Terror wrote:A 110/90 X 10 will fit without touching the bumpstop, you'll need to fit a spacer under the cone though. MB sell them, and they work well.
thanks for that info.
It depends how far your rear hub cone fits into the hub son only go halfway in :roll:
