Is this right? Strobing
Snails
Trying to strobe my timing but the strobe aint flashing
Wired up to 6 month old battery that I took out of my car when it was scrapped yesterday so I know the battery is good
Red to positive, black to negative and running the scooter rather than using a drill
Cant see why its not working, its brand new so I'm wondering if its faulty
Some of the sensors have a direction arrow on them.
10 inch Terror
Xbox live gamer tag: No.
The arrow should point toward the spark plug ( which it is .) If the battery is ok and connected correctly, it should work.
holty
Main scooter: lambretta gp
Had the same trouble a couple of weeks ago, battery wasn't charged enough, so connected my battery charger at the same time and it worked fine, might be worth a try.
Snails
Thanks for the idea. Guess I will have to see if I can get a replacement
YAMLAM
if it`s a draper one ,the bulbs dont cost the earth, had to replace mine after someone borrowed it.
win or lose have a booze
EddieStone
Battery probably needs to be at 12V. Charge it up and give it another go.
Livi- Graeme
Main scooter: Lambretta li 185 series 2
Have you got the engine running whilst you hold the trigger.
vespanic
Have you tried earthing to the frame rather than the battery?
lambro
Try a different CDI, I have trouble with various ones strobing.
Swap CDI for a Ducati one I have I know works, and almost always get a flash.
Shaun.
