whats the pro's and cons
roadrunnerian
thinking of getting a spare engine have a tsi225 top end but was offered a 225 Monza kit is there any pro's and cons of the Monza or just keep the ts1 thanks
Reed valve recessed into the inlet manifold to give more frame clearance on the newer Monza kits and manifold fits 30mm carbs.
AF manifold is to fit 34mm Dellorto. Pro or a con on that depends on what carb you are thinking of using.
roadrunnerian
thanks Martin for the reply I have a spare ts1 top end complete with manifold and exhaust might stick with that tmx35 for me ;)
