ts1 jetting
smoore-gt225
Main scooter: lambretta GT200
Hi I cant seem to get rid of stuttering four stroking, plug chops etc all ok,
its just in the mid range and I cant pull it through it unless I knock it down a gear and rev it out before I change up
ts1 with a delly 30mm phbh
av268 atomiser
138 main
x7 needle top clip
55 idle
350 float
timing at 18 degrees
it is really unrideable between 40-55 as just sits there stuttering and wont accelerate
any advice would be appreciated
cheers steve
db67
Hi , don't know if this will help but i run the following on my ts 225 - 40 slide,137 main,55 pilot,av 266 atomiser,x13 needle (2nd clip down from the top ) 300 float jet, i also run it with a ram air filter mounted on the top of bellows & coupled with a bgm clubman, I do get a little 4 stroking between 1\2 & 3\4 throttle but nothing major & it soon clears, hope this helps & you get it sorted. db67 ;)
wack 63
Main scooter: '71 GP TS1
Being as your needle is on the top clip, I'd be inclined to try a 266 with the X7 on the bottom notch then move up one notch at a time till it runs clean. Pay attention to the plug but I will say that most TS1's have a stutter in that range just before it comes on song, some worse than others.
smoore-gt225
Hi thanks for replies
wack 63 wrote:Being as your needle is on the top clip, I'd be inclined to try a 266 with the X7 on the bottom notch then move up one notch at a time till it runs clean. Pay attention to the plug but I will say that most TS1's have a stutter in that range just before it comes on song, some worse than others.
moving needle to bottom clip, surely that will make it even worse and richer wouldn't it
wack 63
The smaller atomiser delivers less fuel so hopefully it will stutter on the bottom notch, then you can move the clip up one notch at a time till it runs clean.
smoore-gt225
wack 63 wrote:The smaller atomiser delivers less fuel so hopefully it will stutter on the bottom notch, then you can move the clip up one notch at a time till it runs clean.
Hi Wack 63 I finally got round to playing with scoot today and could not get it to run right with any combination
in the end it was the ducati cdi was failing, changed it and re did jetting and running sweet now
cheers
wack 63
    Users browsing this forum: Semrush [Bot] and 6 guests
