Outer rear brake cable.
Posted: Sun Jul 10, 2016 2:25 pm
by 10 inch Terror
Re: Outer rear brake cable.
Posted: Sun Jul 10, 2016 2:58 pm
by cgt75b
My opinion is "leave it well alone" it will be fine.
Posted: Sun Jul 10, 2016 3:01 pm
by Mag
Looks right to me
Posted: Sun Jul 10, 2016 3:02 pm
by bazza3004
I cut about half inch off my outer it wasnt a bgm cable though. Think you need bit of extra length on outer for engine movement.
Posted: Sun Jul 10, 2016 3:14 pm
by 10 inch Terror
Cheers fellas, I'll leave it as is then.
Posted: Sun Jul 10, 2016 3:56 pm
by garry inglis
mine was same 10 inch i tywrapped it to frame out the way of plug
Posted: Sun Jul 10, 2016 4:12 pm
by HxPaul
Mine is the same length,I route my outer to the inside of the plug.
Posted: Sun Jul 10, 2016 5:42 pm
by wack 63
When you fit the cable plate behind the choke lever it will probably be the right length and keep it away from the plug.
