Rear wheel ticking noise
Posted: Sat Jun 18, 2016 3:39 pm
by thackers
Hi, I'm looking for some guidance on a ticking noise coming from the rear wheel/hub. I've had the scoot on a dyno today and noticed the noise and a slight wobble as the wheel spun. There seems to be no play when rocked by hand and the wheel nuts are tight. Can anyone point out where I might have the problem please? Could it be a bearing? Also if I were to change the layshaft which one to go for would be advice that is kindly received. Thanks.
Re: Rear wheel ticking noise
Posted: Sat Jun 18, 2016 4:39 pm
by Monty
I would remove a couple of the nuts to be sure the holes have not elongated out also that your nuts are not the domed ones that may be tight but not gripping the rim. I know obvious first
Posted: Sat Jun 18, 2016 4:50 pm
by thackers
I'll check them out again and to see if the holes are elongated, which I hope not as the rims are sip ones.
Posted: Sat Jun 18, 2016 4:54 pm
by bazza3004
If your using split rims ive yet to see a set that dont have a slight wobble. When i rebuilt my mates motor a while back i noticed a ticking noise when the hub was rotated backwards. Not sure what exactly was causing this but upon replacing the hub bearing and re shimming the g.box the noise stopped.
Posted: Sat Jun 18, 2016 5:51 pm
by Adam_Winstone
I've had a bearing tick that turned out to be the bearing's race had gone bye bye and all of the balls were sitting at the bottom of the bearing. I've also had the same issue that others mention, that of rims moving on the hub studs, elongating rim holes and wearing through studs!
Best checked out.
Adam
Posted: Sat Jun 18, 2016 8:57 pm
by Daggs
Probably either a gear cable or the clutch cable touching the wheel.
Posted: Mon Jun 20, 2016 6:42 pm
by thackers
Thanks everyone, I haven't had chance to check it yet but when I do I'll report back with findings.cheers
