No Spark
Jonn
Never had a problenm starting my scoot second kick every time.Now tonite all of a sudden it started,no reading on rev counter(clamp on HT lead type) spluttered pulling away and 50yds down the road stopped.Got it home no spark.No spark from green wire straight from staor either.Ohms readings are good and have continuity in all cables. HT lead ok too although not thru plug cap (?) Any ideas ?
Have you tried it with the green that goes into loom disconnected from the cdi?
Jonn
Yes I have.
Jonn
Fitted new stator and have a spark, yay. I'm guessing the white Low tension coil isnt supposed to be toffee coloured ?
Burnt out
Jonn
Is this the only thing to replace,nothing else would be damaged? Is it n easy job,I see you can get all the parts needed.
