Interesting modification/bodge,what do you think?
kevspeed
Quite a while back i picked up a job lot of Lambretta stuff,picked out the parts i needed there and then,and stashed the rest away for future use.
Today i dragged the stashed parts out as im going to put together a standard 150 motor to use as a spare.
Amongst the stuff is a fairly tidy Li 150 casing,complete with endplate/gearbox/and layshaft all fitted.
Upon dismantling,to check exactly what gearing was fitted i found this modification/bodge to the layshaft/endplate bearing!
It all turns very smoothly and is all a very nice fit. The bearing is of Japanese manufacture and is a 6201,which is also the size for the front wheel.
What do you all reckon?,good,bad,safe,dangerous,clever,bodge?
a.lo.v2
Main scooter: sx 200
must be a pig to seperate, doe the endplate come off the bearing or come off the layshaft with the bearing or bring the layshaft out as well? shimming?
kevspeed
This particular one left the bearing on the layshaft which i then managed to get off by gently tapping.Its a lovely fit,no play,so someone took the time to do it properly!
MB used to do this to repair the bottom bearing face of the gearbox xmas tree. It was a good way to salvage the part and return it to use. More an engineered fix than a bodge. Looks like someone has done the same to the end of the layshaft for similar reason.
Adam
10 inch Terror
Xbox live gamer tag: No.
That looks very well done. I certainly wouldn't call that a bodge.
wack 63
Main scooter: '71 GP TS1
I've often wondered why Innocenti didn't do this but then again look how small the layshaft has been machined down to, 12 mm? They must have had a reason to use a bush and needle rollers in the endplate even if it was just to gain some meat on the layshaft stub. I'm not aware if the layshaft can be machined and a bush fitted like the cluster to repair pitting.
I think it can. I'm told MB do a special bush for a pitted layshaft.
Rich_T
Main scooter: Li Special
Please check the load ratings for the needle original needle roller v the ball bearing replacement. You may well find the needle roller has much more load capacity.
kevspeed
wack 63 wrote:I've often wondered why Innocenti didn't do this but then again look how small the layshaft has been machined down to, 12 mm? They must have had a reason to use a bush and needle rollers in the endplate even if it was just to gain some meat on the layshaft stub.
That's what I was thinking when I saw this!,I'm now wondering,if I did use this,how long would it last,and is the machined end strong enough?
