Sat Nav
jonboy
Main scooter: Vespa T 5 Classic
Can anyone recommend a good sat nav and fixing kit
For a Lambretta
Donnie
Have you got a hydraulic front brake setup?
Donnie.
jonboy
No just standard front brake lever
Muppet
https://youtu.be/Sq1kcLDJzWA these are good whichever satnav you fit youll have work out how ya gonna mount it,
C’est la vie
Donnie
jonboy wrote:No just standard front brake lever
Ah bugger, was going to suggest a decent satnav app for your phone etc and use a case and clamp off ebay that'll fit a hydraulic disc mount.
Donnie.
Timbo
Well I've cracked it with this and it bolts directly onto where the large bar screws are and is very adjustable. Make sure the bolt you use isn't too long as it will foul the throttle rod. If you want some pics of mine let me have an email addy...
http://www.ebay.co.uk/itm/Jawa-CZ-125-H ... 0814748073
Get a proper bike sat nav as it will be water proof. I prefer Garmin.
Train Driver
This is mine fitted to the brake reservoir and powered through a double usb connector that is connected to a mod charger.
