PHBH 30mm float full of fuel
Train Driver
Why ?? Does it happen to the all black floats ??
Has it happened to "you"
ArmandTanzarian
Could be ethanol in modern fuel destroying the glue.
storkfoot
I have had this happen on the floats in Dell'orto SI carbs and I have seen examples on PHBh too. Poor glue, ethanol in fuel??
wack 63
Main scooter: '71 GP TS1
Why not email the pics to Eurocarb to investigate? Who knows it may make Dellorto revise the floats.
Shipleystevep
One of the floats on mine is half full :cry: :cry:
Train Driver
wack 63 wrote:Why not email the pics to Eurocarb to investigate? Who knows it may make Dellorto revise the floats.
Message sent to them earlier
kejj
Had this happen to my phbh 28bs carb. To the float that the carb left the factory with.
In iron Lambretta cylinders we trust!
________________________
http://tv175.wordpress.com/
garry inglis
Swap it for the black ones there ok
Train Driver
Ok hopefully now sorted, emails back and forth with dellorto uk and they tell me uk supplied carbs have the black floats so that's what I've ordered.
White floats are only for our friends on the mainland :o
warts
Main scooter: honda
My guzzi has had black floats since 1979. Same Del Orto PHF's.
The same black floats, the same as fitted by Giovani way back when.
