Could I? Should I?
Posted: Wed May 18, 2016 8:39 am
by 10 inch Terror
Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
Re: Could I? Should I?
Posted: Wed May 18, 2016 10:21 am
by eden
Buy an LI sidecase
Posted: Wed May 18, 2016 10:23 am
by drunkmunkey6969
10 inch Terror wrote:Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
Yes....i do it on the Winco pressure plates all the time.
Posted: Wed May 18, 2016 10:49 am
by 10 inch Terror
drunkmunkey6969 wrote:10 inch Terror wrote:Hi all, I have the older type LI150 gearbox, with the hole through the Xmas tree. With it, I have the matching LI clutch pressure plate with the spline that guides it into the Xmas tree. Now obviously it has the nipple on it. Could I, should I grind that off to enable me to use a GP side casing? I like the idea of the guide helping keep everything central. Any advice gratefully received.
Cheers drunkmunkey.
