Stage 6 EGT gauge mounting ideas?
Posted: Sat May 07, 2016 11:39 pm
by alanscottj
I have a Stage 6 EGT gauge and have always had it attached to the top of my spare wheel using Velcro. I have just taken off the spare wheel and need to mount the gauge. Any ideas on brackets or other mounting solutions ? Many thanks
Re: Stage 6 EGT gauge mounting ideas?
Posted: Sun May 08, 2016 9:54 am
by rosscla
Make a little bracket to attach under / by the light switch using the two screw that hold the thottle housing.
Posted: Sun May 08, 2016 5:51 pm
by alanscottj
rosscla wrote:Make a little bracket to attach under / by the light switch using the two screw that hold the thottle housing.
I have a choke lever there
Posted: Mon May 09, 2016 9:13 pm
by wack 63
If you've removed the wheel carrier why not make a bridge with an angled plate for the gauge to fix to the lower horncast screws?
Posted: Mon May 09, 2016 9:40 pm
by alanscottj
wack 63 wrote:If you've removed the wheel carrier why not make a bridge with an angled plate for the gauge to fix to the lower horncast screws?
Sorted! Found a little bucket I bought from B&Q for something totally unrelated, bent it a touch, and fixed to the little bolt that hold the leg shield trim end cap
Going to route the cables down the horn cast. Happy days
Posted: Tue May 10, 2016 11:36 am
by alanscottj
alanscottj wrote:wack 63 wrote:If you've removed the wheel carrier why not make a bridge with an angled plate for the gauge to fix to the lower horncast screws?
Sorted! Found a little bracket I bought from B&Q for something totally unrelated, bent it a touch, and fixed to the little bolt that hold the leg shield trim end cap
