Stage 6 EGT gauge mounting ideas?
alanscottj
I have a Stage 6 EGT gauge and have always had it attached to the top of my spare wheel using Velcro. I have just taken off the spare wheel and need to mount the gauge. Any ideas on brackets or other mounting solutions ? Many thanks :D
Make a little bracket to attach under / by the light switch using the two screw that hold the thottle housing.
alanscottj
rosscla wrote:Make a little bracket to attach under / by the light switch using the two screw that hold the thottle housing.
I have a choke lever there ;)
wack 63
Main scooter: '71 GP TS1
If you've removed the wheel carrier why not make a bridge with an angled plate for the gauge to fix to the lower horncast screws?
alanscottj
wack 63 wrote:If you've removed the wheel carrier why not make a bridge with an angled plate for the gauge to fix to the lower horncast screws?
Sorted! Found a little bucket I bought from B&Q for something totally unrelated, bent it a touch, and fixed to the little bolt that hold the leg shield trim end cap :D
Going to route the cables down the horn cast. Happy days :D
alanscottj
Sorted! Found a little bracket I bought from B&Q for something totally unrelated, bent it a touch, and fixed to the little bolt that hold the leg shield trim end cap :D
