Page 1 of 2
Scootopia 22mm carb set up
Posted: Mon Apr 25, 2016 7:20 pm
by Scootermonkey
Hope it's ok to post this here, seems to be read by more than on the carb page.
AF Rayspeed 175 top end, standard exhaust, and a Scootopia 22mm carb. I have a 150 atomiser and slide, and a 200 atomiser and slide as supplied with the carb. Anyone know the best combination of slide and jets to suit the 175 set up? Thanks
Re: Scootopia 22mm carb set up
Posted: Mon Apr 25, 2016 7:55 pm
by Doom Patrol
200 slide. I would have thought the 45 pilot would be okay. Main, possibly 118 - 120.
Posted: Mon Apr 25, 2016 8:42 pm
by Tractorman
Doom Patrol wrote:200 slide. I would have thought the 45 pilot would be okay. Main, possibly 118 - 120.
I struggle to understand jetting the recommended main jet for a standard GP 200 with a 22mm carb is 118. My 225 mugelo has a 25mm phbl and the main jet is 102, it's been set up on a dyno and runs well. Why is this?
Posted: Mon Apr 25, 2016 9:04 pm
by Scootermonkey
Puzzles me too. GP150 main jet 118, same as a 200
Someone suggested a 122 main for the 175 set up. ??
Posted: Mon Apr 25, 2016 9:43 pm
by Doom Patrol
Tractorman wrote:Doom Patrol wrote:200 slide. I would have thought the 45 pilot would be okay. Main, possibly 118 - 120.
You can't really compare the two. The jets on modern carbs seem massive by comparison and can't be interchanged with the original jetting. It's best to think of them as a different range altogether. You sort of start from scratch with the modern Dell'orto's with another set of rules.
Posted: Mon Apr 25, 2016 10:30 pm
by shocky
my jettex runs a 135 main altho the atomiser has been modified to flow more mid range andits a indian 200 with scootrs pipe runs lovely
Posted: Tue Apr 26, 2016 9:14 am
by Tractorman
Doom Patrol wrote:Tractorman wrote:Doom Patrol wrote:200 slide. I would have thought the 45 pilot would be okay. Main, possibly 118 - 120.
So will a scootopia carb with an 118 jet use more fuel on than a modern card with a smaller jet?
Posted: Tue Apr 26, 2016 9:25 am
by rosscla
very unlikely
Posted: Tue Apr 26, 2016 11:31 am
by a.lo.v2
it amazed me in the latest scootering when tuning a standard indian gp200 with an ancilloti and a 22mm carb ended up needing a 175 main jet!!
Posted: Tue Apr 26, 2016 1:31 pm
by bristolmod
a.lo.v2 wrote:it amazed me in the latest scootering when tuning a standard indian gp200 with an ancilloti and a 22mm carb ended up needing a 175 main jet!!
a typo surely??? 115 more like it
