Speedo behaviur question
kejj
My speedo works fine for a while and then staring to act up.
Basically I've come to the conclusion that it works fine for 1 hour or so appropriately and then starts showing lower speed figures. After a brake it would be fine again for a while and start acting up in shorter time.
If put at rest to cool then it would work for about 1 hour again.
It does not stop working, just show lower speeds and jump up and down between actual speed and lower figure.
Should I suspect the speedo or the worm/plastic part on wheel?
I have this speedo: http://www.scooter-center.com/en/produc ... ENTE_TACHO
________________________
http://tv175.wordpress.com/
HxPaul
I've yet to see an after market speedo that works properly for any length of time.
EddieStone
Have you oiled the cable?
