gp200 stator
Posted: Thu Apr 21, 2016 11:10 am
by mickfeath.
Hi, can anyone tell me if you can check a stator to see if it's faulty ? Also are they easy to change ?
Re: gp200 stator
Posted: Thu Apr 21, 2016 3:16 pm
by HxPaul
You can do a static test if you have a multi-meter,all the figures are in "stickys" manual.Unfortunately when the scooter is being used with the dodgy stator it could break down when it gets hot.
Re: gp200 stator
Posted: Thu Apr 21, 2016 3:36 pm
by EddieStone
They are easy to change - you'll need a flywheel removal tool, and a flywheel holder. Once the flywheel is off, three bolts hold the stator in place, and a cable clamp holds the wiring through the top of the mag flange.
If you change it you'll have to check the timing, best done with a strobe gun. The nut holding the flywheel on is left handed.
Re: gp200 stator
Posted: Sun Apr 24, 2016 11:56 am
by mickfeath.
Thanks for replying to my post, i have sorted my problems out, Thanks again for your knowledge, Mick.
