gp200 stator
mickfeath.
Main scooter: lambretta super vijay 150
Hi, can anyone tell me if you can check a stator to see if it's faulty ? Also are they easy to change ?
HxPaul
You can do a static test if you have a multi-meter,all the figures are in "stickys" manual.Unfortunately when the scooter is being used with the dodgy stator it could break down when it gets hot.
EddieStone
They are easy to change - you'll need a flywheel removal tool, and a flywheel holder. Once the flywheel is off, three bolts hold the stator in place, and a cable clamp holds the wiring through the top of the mag flange.
If you change it you'll have to check the timing, best done with a strobe gun. The nut holding the flywheel on is left handed.
mickfeath.
Thanks for replying to my post, i have sorted my problems out, Thanks again for your knowledge, Mick.
