Has anyone changed a engine mount on a Piaggio Leader engine
- scooterslag
- registered user
- Contact:
noticed one of my mounts was looking a bit knackerd when changing the belt on rollers on my Piaggio Hexagon, thought it would be ok but no... handles like a dog, anyone changed a mount on a Leader engine? (GTS, X9, Hexagon, B125 etc) if so, what sort of job was it? cheers Paul
The mack daddy on the left!
Do you mean the swing arm bearings ?
- scooterslag
- registered user
- Contact:
Nope, thisshocky wrote:Do you mean the swing arm bearings ?
http://www.ebay.co.uk/itm/PIAGGIO-HEXAG ... SwwPtTv6iE
I did one on a dragster and it was a right pain I made 2 6 mm thick discs with a 12mm hole in each and a length of brand 2 nuts .I also chamfered the edge to help start it to feed into the hole .it says engine mount in that listing but it's more of a vibration damper
Sent from my SM-G903F using Tapatalk
Bar not brand
- scooterslag
- registered user
- Contact:
Yeah looks a bit of a sod of a job, worst bit will probably be undoing /loosing all the various pipes, cables and such gubbins
I changed all mu hoses with blue silicone ones at the same timescooterslag wrote:Yeah looks a bit of a sod of a job, worst bit will probably be undoing /loosing all the various pipes, cables and such gubbins
- scooterslag
- registered user
- Contact:
yeah might be a good chance to check/overhaul all that kind of thing at the same time
