lui 50 cl
li mick
has anyone a wiring diag for a lui 50 cl,it runs, stops using the cut out switch,but now in need of diag for lighting.thanks,mick.
wack 63
Main scooter: '71 GP TS1
There's not a lot to the wiring on a Lui, very basic as no brake light etc.The colours are basically the same as the 75 Vega so a diagram will be easier to find for one of those, like in the old workshop manuals.
li mick
thanks wack,the harness i fitted only has the green,brown,from the junction box to the headlight the rear light wires come out of the harness and thats it, oh i have one to the horn.looks like running more wires in.the engine runs ok and stops on the cut out switch so just the lights to get going now.
wack 63
From memory, I seem to remember there's brown, green and black into the headset which then go to the switch to turn the lights on and off, ignition kill and horn earth.
li mick
cheers wack,i'll give it a go.
