Advice for gear selection issues ..........
alanscottj
Evening! Having issues with my gears. When riding I am finding it difficult to select gears, particularly when coming to lights/junctions. Sometimes I really have to give it some to get it into gear. Any advice appreciated as always :D
Chris in Margate
Change clutch plates and check that new ones are free to compress and not sticking.
alanscottj
Chris in Margate wrote:Change clutch plates and check that new ones are free to compress and not sticking.
Brand new clutch mate, af 6 plate cassette. It feels more like its the selector :?:
lambro
I have just been through the same, clutch wouldn't drag when sttod in gear at a junction, it would slip when I kickstart and pull the clutch,
But I couldn't select neutral no matter how hard I tried whilst stood.
Turned out to be warped steels, and uneven heighted springs.
I got replacements from AF, but one the the new steels was more warped than some of the old ones, so I picked the best and all good now.
Road clutch, not the race one.
Shaun.
mick1
Main scooter: Li Avanti 225
Clutch and gear cables in poor condition ?
Gear wheel in headset loose or worn ?
HxPaul
If its got a GP type gear selector sometimes the splines are cut wrong.When you select first gear the swivel hits the base and sometimes prevents selection.
bristolmod
clutch cable not adjusted correctly? I had the same symptoms with a standard set up and have always adjusted mine as per the original Work Shop Manual (gap between top lever and shoulder of 1/16th inch). I've found I have to decrease the gap to allow good selection- particularly coming up to lights etc) Could be that the cable has stretched?
AMENDED- I ORIGINALLY PUT "GEAR' INSTEAD OF "CLUTCH" MY BAD!!
Chris
Scootering since 1968.
dansacred
Main scooter: li 150 series 3
you have the uprated selector spring?
alanscottj
Thanks all, I think I'll try with adjusting cables to start with see if that helps, they may well have stretched. If no joy then I have a new uprated selector spring that I'll stick in there next time I have to open her up.
dansacred
why I was asking was because I feel the uprated spring is a bit too strong, anyone else find this?
    Users browsing this forum: Google [Bot] and 16 guests
