Wassel battery
gp200ts1
Main scooter: lambretta series 2
Looking for a slim battery for my Wassel conversion. Thing is to put it where I want it can't be more than 50mm wide. What are others using and anyone know of thin batteries of 5amp plus?
ArmandTanzarian
I tried burglar alarm batteries but they kept going flat. You could try a modern NiCad but they aren't cheap.
Monty
I think you will struggle to get anything alarm battery wise in 5 amp that's that slim. The one I'm using is slimmer than that but longer and is under 3 amp. I have a 5 amp one on my other bike and its about 4.5 x4x 4.5 inches. Sorry I'm a feet and inches man. That's on my imola bike that I rarely ride and its never gone flat. I did loose one that went flat as I had switched it passed off to parking lights. If you are draining a battery something must be drawing power. My ignition switch turns everything off. As I had a digital speedo and it only works with the lights on. The imola is wired standard but still doesn't have a problem. I would be looking at rear light especially if you are using a LED lamp.
Most Maplin stores stock the alarm batteries so you could just go in and have a measure up. Bare in mind that you can use 2 small batteries connected in parallel to achieve the desired capacity. That might make it possible to mount them in different locations. Early MGB's had a similar arrangement due to mounting space issues.
Knowledge
Try this spec sheet from Yuasa.
http://www.yuasabatteries.com/pdfs/Yuas ... s_2015.pdf
All the dimensions are there. Burglar alarm batteries are the way forward. Mine has not gone flat, it won't leak and it can be mounted at any angle (except upside down).
Do it.
Martin
mick1
Main scooter: Li Avanti 225
I had no joy with the alarm batteries. Had to buy a new one every year and it struggled to charge on the scooter, continuously took it off to mains charge in the garage. I suspect they don't like the cold and the vibration.....
Fitted a "wet" cell battery in one of them rear oil carriers and not had any issues.
Donnie
The space
ImageIMG_2857 1 by Donnie Canning, on Flickr
PX Battery tray with side dremelled off and attached to back of toolbox where your air filter normally goes.
ImageIMG_2858 1 by Donnie Canning, on Flickr
bought this http://www.ebay.co.uk/itm/301855488535? ... EBIDX%3AIT
which is a AGM better and service free version of http://www.mdsbattery.co.uk/shop/produc ... oupID=1029 which is what I did have and was tired through being run down
and all fitted.
ImageIMG_2864 1 by Donnie Canning, on Flickr
Donnie.
MOre or less the same
ArmandTanzarian
I put my battery here. works well but its a pain in the bum if you get a puncture.
Burnside
Main scooter: Lambretta TV200
I'm using an alarm battery on my API, it doesn't have a battery tray so is sitting between the rear mudguard and frame loop. Been in there for about 4 years and hasn't run flat yet.
    Users browsing this forum: Amazon [Bot] and 4 guests
