I have a s3 Li150 with a Jetex carb. Engine and exhaust are stock as far as I can tell.
I'd like to buy a new carb for the scooter. Would a PBHL 20 be a good standard option?
What carb to buy
Tractorman
- registered user
- Main scooter: Lambretta li150 special
- Contact:
Had you considered a scootopia 22mm should fit straight on.
- registered user
- Contact:
Jetex can be a problem, but if fettled carefully can work. The Scootopia sh2/22 is a better choice nowadays.
If you want a modern carb the PHBL or a PWK type at 24 mm could be good and you'd stil be able to use the airbox.
