Clutch Slip Fix - plates & springs
H,POOL GADGE
Question Lads! struggled today like coming back from Whitby, with an head on wind and me polini 220 wanting to push on through it, thus causing the clutch to slip(a first for me)...question is best plates ie...cork, newfren, surflex, carbon and best stiffer springs ie...malossi, taffspeed, sip sport, dr...combination???
clutch setup now...banded cosa, newfren plates, beedspeed 25% extra springs(seems springs are shite)!!!cheers lads.... :D
Jack221
Main scooter: PX221
Do you think your scooter is only 25% faster than standard? ;)
I have had similar issues with mine. Tried many combinations but in the end it's all about the springs.
I suggest to just get a set of these XXL from SIP and it will never be an issue again.
http://www.sip-scootershop.com/en/produ ... a_93122010
H,POOL GADGE
cheers jack221, afta beedspeed f*^ed me order up 3 times I ended up with 25% extra springs(obviously shite), been looking at the sip xxl's, i'll see if plates are burnt before I order....
