jocky's boxentop
mickfeath.
Main scooter: lambretta super vijay 150
Hi, i am thinking of buying one of these kits to see if it will cure the problem with my rear brake on my sil gp200, my concern is that it says it is not to be used on public roads, is this the case ?
dansacred
Main scooter: li 150 series 3
painful to set up but works very well.
jonzo172
The "not to be used on public roads" bit is just their disclaimer to protect themselves against potential litigation.
DigDug
dansacred wrote:painful to set up but works very well.
+1
Did you have to do that?
mickfeath.
Thanks Jonzo172, now all i have to do is order 1 and fit it, and thanks to Dansacred and Dig Dug for preparing me for the awkward fitting, Thanks Mick.
DigDug
mickfeath. wrote:Thanks Jonzo172, now all i have to do is order 1 and fit it, and thanks to Dansacred and Dig Dug for preparing me for the awkward fitting, Thanks Mick.
It's easy to fit but fiddly to set up correctly.
I had to take a couple of time-outs to avoid throwing it all through the garage window, however finally got it sorted and the results are dramatic.
Arborman
Main scooter: RB22
Work well to be honest.... and real easy to set up...get someone else to do it!!!
DigDug
Arborman wrote:Work well to be honest.... and real easy to set up...get someone else to do it!!!
That would work.... 8-)
mickfeath.
Wish there was someone around here to do it , but no one is volunteering.
sydduckett
I had to take mine off, just couldnt get it to work, but to be fair it may be the hub
