RB 20 Temporary replacement
kevspeed
After the RB 20 problem,we are in the process of finding a temporary replacement till the necessary cash can be saved to repair it.
I have dug out an old but good Suzuki 190 kit,inc carb and pipe,BUT...............The RB set up has a 116mm rod,and the 190 kit was designed for a 107mm rod,this means im looking at a 9mm packing plate at the base of the barrel,this should work,but does anybody make them?
EddieStone
Can you use a 5mm and a 4mm?
kevspeed
Sorted via 'Chiggy',at Lambretta Upgrades.
