Servetta Motoplat Stator Wires
Posted: Tue Feb 23, 2016 2:49 am
by Lamaddict
It's running on points but where do the 2 yellow and 1 red wire go? I'm trying to put on a new regulator but can't work out where they go and what they do. The other wire is green and I know that's for the ignition etc.
Re: Servetta Motoplat Stator Wires
Posted: Tue Feb 23, 2016 12:26 pm
by Muppet
wires to a motoplat regulator rectifier then jbox to loom
Posted: Tue Feb 23, 2016 1:04 pm
by Lamaddict
I get that but I don't have the Motoplat Rectifer but another type to try and use. If I knew what the others wires did it would be great and once I know this I should be able to work it out.
Posted: Tue Feb 23, 2016 10:41 pm
by wack 63
If you want a Motoplat reg , a mate may have one or two.
Posted: Thu Feb 25, 2016 10:59 pm
by Pepot
If you want to run it on A/C, forget the red one and isolate it, put one yelow to ground and the other to an AC regulator. If you wish to run DC, buy a wassel regulator,join the yellow wires fronm stator with the yellow of regulator and isolate the red one from stator.
