Servetta Motoplat Stator Wires
Lamaddict
It's running on points but where do the 2 yellow and 1 red wire go? I'm trying to put on a new regulator but can't work out where they go and what they do. The other wire is green and I know that's for the ignition etc.
Muppet
wires to a motoplat regulator rectifier then jbox to loom
C’est la vie
Lamaddict
I get that but I don't have the Motoplat Rectifer but another type to try and use. If I knew what the others wires did it would be great and once I know this I should be able to work it out.
wack 63
Main scooter: '71 GP TS1
If you want a Motoplat reg , a mate may have one or two.
Pepot
Main scooter: servetta LI150 serieIII GT186
If you want to run it on A/C, forget the red one and isolate it, put one yelow to ground and the other to an AC regulator. If you wish to run DC, buy a wassel regulator,join the yellow wires fronm stator with the yellow of regulator and isolate the red one from stator.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 5 guests
