px wide rim
ducksta
Wanting to do a wide rim conversion on my px engine what bits do i need or is they a complet kit i can buy looking on sip site they are loads of differant bits, just need clarification of what i need cheers
cartmel808
Ive done both mine with the scooter & service conversion https://www.scooter-and-service.de/larg ... l-komplett ...the basic kit consists of a billet rim spacer to go between the wide halves of a px & a cosa rim, 5 bolts to replace yr existing hub studs & a 10mm spacer for the swing arm - or you can pay more & buy the fully built-up wheel/tyre set-up from them (as in the link)
ducksta
£66 spacer rims and packer from sip does this sound right aldo what tube do i need for the 170 tyre
cartmel808
Not used the SIP kit before - so not sure what's required with theirs... 130 section tyre is widest you can go & they just take the same standard inner tube as you'd use on a 3.50/10 tyre.
The beauty of the SIP wide tubless rim is that they have already build the off set into it. You don't need to use that ugly spacer or use odd rims or a spacer between the rims as with some other kits. In the kit you get the one piece rim and a small ally spacer for your engine case. Cutting a small amount off it is un-avoidable, (10mm). Tyre width wise you can use 110-120 or 130. A 130 section has a very close ratio to a 3:50 x 10. A 3:50 has an outside diameter of 634.50mm and the 130 is 631.9mm.
nam65
Main scooter: t5
Hi all
Been thinking of doing this also,with the sip wide rim kit do you just need their rim kit which comes
with the engine mount spacer and a tyre as this seems the cheapest way.
thanks
cartmel808
T5-190 wrote:The beauty of the SIP wide tubless rim is that they have already build the off set into it. You don't need to use that ugly spacer or use odd rims or a spacer between the rims as with some other kits. In the kit you get the one piece rim and a small ally spacer for your engine case. Cutting a small amount off it is un-avoidable, (10mm). Tyre width wise you can use 110-120 or 130. A 130 section has a very close ratio to a 3:50 x 10. A 3:50 has an outside diameter of 634.50mm and the 130 is 631.9mm.
This is initially the way I wanted to go with mine - but for some reason sip have discontinued their wide tubeless rim now.... which is a shame coz it does seems the easiest & neatest way of doing the wide tyre conversion & with the added benefit of being tubeless.
nam65
Main scooter: t5
has antbody had any issue wih the flywheel cover hitting the panel
when shifting the engine over
Thanks
nam65 wrote:has antbody had any issue wih the flywheel cover hitting the panel
Thanks
I had a little trouble on the T5, but a bit of pulling on the bottom the side panel helped.
Just had a look on the SIP site and their out of stock for a few weeks. So worth the wait.
