Engine oil
woody
Whats the best grade of engine oil to use in a tuned lambretta with a cassette clutch chaps ?
Same as any other ST90
Tractorman
Oiltek recommend 85WT in LTH clutches.
woody
Cheers , but what i meant was is there an upgrade in oil grade from the standard st90
bazza3004
ST90 was great back in the 60's 70' maybe even 80's to. There are far better oils to use these days especially when using in tuned engines or with cassette type clutches etc.
I run a tuned ts1 230 with an AF cassette and found i got slip when i used ST90. I swapped to motul 2t 10/30 transoil and havent had a problem since.
Ive always usec sae 30 classic 5 lts for about 18 with a motor club membership at my local roadabusers
